The DOS Protection application could not register the required libraries to startup the application.
This problem might cause the DOS Protection application to fail at startup. If this happens again after a reboot, get in touch with Extreme Networks Technical Support (Who will need to get in touch with Engineering) to determine the cause.
Error
Failed starting library group %group%: %error%
| Name | Type |
| group | Char |
| error | String |
